2001 C240 Wiring Diagram .. please --> seat prob
Old Apr 29, 2005 | 02:58 AM
SL600_Cruzin's Avatar
Default 2001 C240 Wiring Diagram .. please --> seat prob
2001 C240 --> I have an interesting problem, which I believe I have traced down. But my wiring diagram is almost unreadable.
The wiring diagram I need is as follows:
I need the wiring diagram where the Front Passenger Side Seat (all motors), the Front Passenger Window, and the Passenger Side Rearview Mirror Mounted Turn Signal all intersect. ie... more than likely their ground connection location.
Old Apr 29, 2005 | 04:56 AM
sleepwalker's Avatar
Default RE: 2001 C240 Wiring Diagram .. please --> seat prob
what's the problem?
VIN?
Old Apr 29, 2005 | 05:38 AM
The problem is that the Front Passenger Side Seat (all motors), the Front Passenger Window, and the Passenger Side Rearview Mirror & Mirror Mounted Turn Signal all stopped working. Once in while they will operate "ALL OF THEM". Which leads me to believe that there's a poor "common" ground connection, but my wiring diagram is a bit messed up and very hard to follow.
It's a client's car and I don't have it in my possession at this moment for the VIN # ..... All I can tell you at this point is that it's a 2001 C240 Loaded with everything except integrated phone and Does not have the Bose Stereo.
Old Apr 29, 2005 | 10:59 AM
door control module
Old Apr 29, 2005 | 01:18 PM
Sleepwalker .. thanks for the quick reply. You are AWESOME !
Old Jun 29, 2005 | 01:51 AM
Sorry for not posting this reply sooner.
Yes indeed it was the door control module located inside the passenger door.
What would happen is that the car would sit with the passenger door towards the sun and low and behold the window, mirror seat etc.. would start working. Then take the car for a spin or get the door out of the sun for a while then everything would quit working.
Hope this helps someone someday.
Thanks Again Sleepwalker !! You are the MAN!!
TJ
Old Jan 18, 2009 | 03:56 PM
davidanthony21's Avatar
2001 C240. Seat control module drains the battery in 2-3 days. I looked underneath the seat and found a bunch of plugs. 4 in the back and 2 or 3 in the front. Which ones do I disconnect? Someone mentioned here that you can splice a wire that is for keeping the seat control on after the car if off, and that should fix the problem. Either way I am completely lost. Any pictures of the steps needed would also help.
davidanthony21@yahoo.com
TONYSLK230
Dec 18, 2007 04:24 PM
andyc240w202
Oct 13, 2007 05:37 PM
Serafym
Feb 3, 2007 01:29 PM
Sassen
Mar 2, 2006 12:46 PM
Dehaven
Dec 21, 2005 12:25 AM
