2000 C230 Kompressor PO170 code
Can anyone help with a problem on my C230 Kompressor. I have a recurring PO170 code, that comes and go's. All vacuum seems to be OK the MAF was changed. Fuel pressure is normal at 52 PSI. The car runs fine but I cannot get it through New Jersey inspection.
Any ideas would be greatly appreciated. Thanks |
Had same problem few months ago on my 03 C230, p0170 code, changed both O2 sensors which solved the problem. Just got a p0304 code the other day with bad idle, will be working on that issue now.
Problem solved
Thanks for the advice. I put an OEM Bosch MAF in and the CEL went off. Went right through NJ inspection. Moral of the story, use only OEM parts. I had originally used an E-bay $65 dollar special. The strange thing is the car ran great with it in.
