1999 C280 Sport. Windows issue
Hello people. Really weird thing happened to me today. I was driving and all the sadden all four my windows would go down at the same time.after they went down, they wouldn't work at all.they don't work now. I can't close them up. And I Live in Iowa. Raining.People, I need your help
Could it be because of water? Some safety thing maybe? I had cup of water and I think some water might go on the panels where all the buttons are. by the way, side power mirrors wouldn't work either. and sun roof would behave weird. it would open. but to close it I have to push the button to lift it up, not to close it.
So if it is a water, any suggestion what should I do? or could it be just fuse? the fuse is the first thing I'm going to ckeck tomorrow morning.
will see.
will see.
Ok, so I took my central panel off.cleaned it.three windows out of 4 worked. one window sounds like motor works, but window doesn't operate. side mirrors worked as well. however, I have a new problem now...
Every time I start my car, trunk opens automatically(
cmon guys, nobody knows what the problem could be? I don't wanna go to stores or services, they won't know. here in US, well at least in Iowa nobody know a thing about Mercedes.(
ok, so I just let it dry up. and It worked.well, at least trunk, three windows and the mirrors. How ever, passenger front window works, but you have to push the button up to make roll down and the button down to roll it up.
weird...
Any way, now have the rule in the car - NOOOOO DRIINKS!!!!!!!!!!
weird...
This model is a generation 1 "smart" computer that interacts with all systems.
My windows get all wacky once in a while too - but if you open the trunk, disconnect the ground for the battery and wait about 2 minutes, then reconnect - a dollar to a donut says all your windows will work fine.
This also works with minor check engine light codes btw.
While the cable is off you might want to just cycle all the switches too about 20 times each - just to clean the contacts.
You'll have to reset the up and down position and the opened/closed on the sunroof and the two front windows. The sunroof will move about an inch at a time till it resets it's own internal memory when opening it after a zero-volts reset like this.
Let us know if this helps please?
So ok, I tried to do it by myself, but couldn't unplug the battery.it's in pretty uncomfortable place and I don't have special tool( So yesterday I went to change an oil and asked them to reset it. Unfortunately, I forgot to tell them to cycle the switches 20 times
As a result it helped for the passenger front window. Now it operates as it supposed to. However all the windows don't work for Automatic position. You know when you push the button twice it rolls down or up automatically. So this is not working now for any of the window. And sunroof works just like you said, step by step. and I didn't get it how should I reset moon-roof?
but at least passenger window is working as it should, up and down. Thanks for that!
As a result it helped for the passenger front window. Now it operates as it supposed to. However all the windows don't work for Automatic position. You know when you push the button twice it rolls down or up automatically. So this is not working now for any of the window. And sunroof works just like you said, step by step. and I didn't get it how should I reset moon-roof?but at least passenger window is working as it should, up and down. Thanks for that!
khwaja
Mar 18, 2009 05:34 PM
