1999 c230 rear rotor replacement
RE: 1999 c230 rear rotor replacement
thanks still could use more info, anybody got a thumbnail pic for me...as you can guess i'm not the sharpest tool in the shed, also AM CURIOUS as to why brake fluid was present,
guess next move to remove wheel, find right two bolts, THEN WHAT????????????
ALSO 1988 MERC 190D rear defrost not working, antena switch on dash does nothing but anten goes up and down with radio,have pirated same switch from junk yard not sure if switch is problem, also noted that white plastic in antena housing worn,
whats the best fix
thqanks
whats the best fix
thqanks
expan the caliper so the brake pads dont get in your way when installing. remove the two 18mm bolts only. drop the caliper, use a T30 torx to remove the rotor retaining bolt. put a lug bolt a few threads into the hub. grab the largest hammer you can find. strike the rotor on the braking area face. once it loosens pull off and reassemble in reverse order. NOTE: you might want to use some loctite on those 18mm bolts.
