1997 C280 WON'T SHIFT OUT OF FIRST.
Old Feb 16, 2005 | 06:23 PM
fuse's Avatar
Default 1997 C280 WON'T SHIFT OUT OF FIRST.
I HAVE A 1997 C280 THAT WON'T SHIFT OUT OF FIRST GEAR. THE CODES ARE 0017 SELECTOR LEVEL CODING INVALID AND 0113 SPORATICALLY SELECTOR CODING INVALID. DOES ANYONE KNOW IF YOU HAVE TO REPLACE THE WHOLE GEARSHIFT ASSEMBLY TO FIX THIS OR IF IT IS JUST THE RECOGNITION SWITCH?
Old Feb 17, 2005 | 12:39 AM
sleepwalker's Avatar
Default RE: 1997 C280 WON'T SHIFT OUT OF FIRST.
if the cables or connectors are loose, it will store the fault as invalid coding.
check the cables and connectors first .
also check the shift rod if it was correctly adjusted.
only then that you can change the GEAR RECOGNITION SWITCH.
Old Feb 21, 2005 | 12:56 PM
fuse's Avatar
I replaced the switch and it fixed it.
Thanks,
Andrew
concord
Jun 16, 2020 02:09 AM
Wedowee
Jul 9, 2010 09:12 PM
goodbunny66
Sep 10, 2009 01:48 PM
laithdogg
Jul 30, 2007 10:24 PM
cisco
May 16, 2004 02:04 AM
