1996 C230K brake system warning lights- help!
Old Oct 16, 2005 | 07:53 PM
Enz's Avatar
Enz
Default 1996 C230K brake system warning lights- help!
Hi Guys,
I would be grateful for any help- In the past week I've started having problems with my 1996 C230K. The following lights come on a few seconds after starting the car and stay on:
-ABS light
-handbrake on-light
-brakepad wear light
also
-speedo doesn't work
-odometer doesn't work
A few days ago they were all intermittant problems, but now the 3 lights stay on (from 2 secs after start-up) and the speedeo & odo don't work 100% of the time. (Also actual ABS doesn't work since this problem started). My car doesn't have ASD.
Hopefully it's a simple electrical connection issue (thought about connector to a wheel sensor) - but where do I start ?
Can anyone help please?
Thanks.
Old Oct 16, 2005 | 08:10 PM
Enz's Avatar
Enz
Default RE: 1996 C230K brake system warning lights- help!
Apologies, just read C280 instrument cluster and danj111's posting sounds the exact same problem.
I will try the overvoltage protection relay fuse, then the relay itself.
Is that the relay attached to the ABS controller ?
Thanks Enz.
PelicanParts.com
Jul 25, 2013 12:22 PM
mattyakb
Mar 10, 2009 07:18 PM
msobug
Jan 10, 2008 11:32 PM
slick1
Jul 30, 2007 07:05 PM
stevey88
Mar 18, 2007 05:19 PM
