1995 c220 looking for cd hookup
Old May 3, 2005 | 06:52 PM
jimb96's Avatar
Default 1995 c220 looking for cd hookup
Hello, Im new to the forum and I would love some help. I have 1995 c220 in immaculate condition and I just purchased an Alpine 6 disc player with the MB adaptor. It says to hook up in the trunk but I cant seem to find where the connector is. I dont want to tear the whole trunk apart to find it. Can someone please let me know the general area to look for the hookup? That would be great. Thanks,
jimb
Old May 3, 2005 | 07:52 PM
C280 wizard's Avatar
Default RE: 1995 c220 looking for cd hookup
Are you sure your head unit is pre wired for a CD player? If so, the cables will be in the trunk, on the same side as the stock mounting area for the factory CD player under the carpet trim in the front of the trunk. Did Mercedes have fiber optic CD connections in 96?
Old May 3, 2005 | 09:34 PM
sleepwalker's Avatar
no D2B in '96 yet.
Old May 4, 2005 | 01:31 AM
SL600_Cruzin's Avatar
This is for the Factory CD Changer.... but it'll give you some info.
1995 Mercedes Benz C 220 (202 Chassis) L4-2199cc 2.2L DOHC
CD Changer: Technical Service Bulletins
Work Instruction
Group: 82
Number: 328
Date: February 1995
SUBJECT:
MODEL 202, M.Y. 1995
INSTALLATION OF CD CHANGER
1. Remove hardware from shipping box and verify contents.
2. Remove shipping screws from CD changer. Place shipping screws in ID card bag. Cover screws holes with dust covers.
3. Remove trunk floor mat.
4. Locate factory bus cable in right wheel well.
5. Attach CD changer to CD mounting bracket using four screws. Ensure that the red WARNING label faces in towards the bracket.
6. Connect bus cable to CD changer.
7. Position CD changer unit into right wheel well so that the stud on the bottom of the mounting bracket fits into the predrilled mounting
point located on side member behind battery.
8. Continue to position the CD changer unit so that the tabs on mounting bracket align over predrilled factory mounting locations.
9. Secure top mounts with screws. Secure bottom mount (stud) with 6 mm nut using a 1/4" drive.
10. Install CD changer cover.
11. Install CD magazine in to CD changer unit.
12. Reinstall trunk floor mat.
13. Test function.
bryan68
Jan 30, 2008 10:09 AM
krl
Sep 12, 2007 07:31 PM
silveramg
Nov 24, 2006 04:24 AM
CLK2000
Nov 19, 2006 04:36 AM
Tin Man
Jun 22, 2004 02:13 AM
