18 VAULT RIMS HELP
18 VAULT RIMS HELP
HELLO, I JUST BOUGHT 18 VAULT RIMS 5X112 7.5 42 WITH BRIDGSTONE 225/45/18 TIRES. WHEN I TRIED TO MOUNT ONE RIM ON THE BACK IT WENT ON SMOOTHLY, SO I WANTED TO SEE HOW THE RIM WOULD ROLL BUT WHEN I PUT THE CAR IN DRIVE THE RIM WOULD SPIN THEN LOCK UP THEN SPIN AGAIN LIKE AS IF IT WAS RUBBING ON SOMETHING. WHEN I LOOKED FOR ANY RUBBING IN THE WEELWELL I COULD NOT FIND ANYTHING TOUCHING. DOES ANYONE KNOW WHAT THE PROBLEM COULD BE????
RE: 18 VAULT RIMS HELP
i have no idea about your new wheel rim.
if you insert the bolt with the wheel removed, the protruding part must be the same as in the old wheel.
a little bit too late now is it? seems you will be needing repair kit for park brake shoe. but maybe it's still fine. take a look inside first.
Gundy75
10-03-2010 11:56 AM
elara61
06-16-2009 01:58 PM
duxdevil
06-19-2006 02:55 PM
