05 C230K Remove Oil Cap - What type Motor Oil
How do you remove the motor oil cap, turn it which way left or right? I tried removing it but it's hard and didn't turn. I stop trying thinking i would crack it.
What motor oil velocity does my car use, 2005 C230K?
You won't crack it......turn counterclockwise to loosen. It's about half a turn and it will come off. Yes, they can get tight.
Here's how I do it when it's that tight.....get a pair of large channel lock type pliers and put a rag on the cap before you
use the pliers. Open them up pretty wide and hold them on the cap straight up in the air while you use your other hand to twist it off. That'll do it. Use Mobil 1 synthetic for this car. This was the factory fill, so stick with it. You can use any of the
weight oils, such as 5-30, 10-30....but there's no need for a "thicker" oil like a 20-50 for your car. I wouldn't use that one.
Once you add oil and replace the cap, make sure it is reinstalledproperly, sometimes it goes on what seems tight but isn't in which case it will leak. Make sure it is well installed.
car5car
Aug 22, 2011 09:17 PM
raltherr
Nov 21, 2010 10:23 AM
raltherr
Sep 3, 2010 04:19 PM
