[ECU] Short circuit to positive -> What does it mean?
Old May 18, 2006 | 10:28 AM
ibestriker's Avatar
Default [ECU] Short circuit to positive -> What does it mean?
Hello experts,
I have sent my ECU to German for repair. When the ECU has been repaired and returned, I asked my Merc Specialist Mechanic to install the ECU.
But there is an error sounds like this:
"IFZ: Short circuit to positive"
What does it mean? Does it mean the ECU is still faulty and not fully repaired? Or is it something else?
Because of that error, the engine won't start, there is a response of the engine sound though, but the red and green LED on the rear mirror keep blinking. The car doesn't want to start.
Hope to get some advices and recommendation.
Many thanks in advance...your help is highly appreciated.
PS: I missed my car, almost 2 months not working..
Old May 18, 2006 | 10:34 AM
sleepwalker's Avatar
Default RE: [ECU] Short circuit to ground -> What does it mean?
the name of your thread is... "[ECU] Short circuit to ground"
but you're asking about.....
what's the fault code (number) and what car?
why did you let mr. german repair it? what's wrong with it?
Old May 18, 2006 | 10:59 AM
ibestriker's Avatar
Default RE: [ECU] Short circuit to positive -> What does it mean?
Sorry, actually the error was:
"Short circuit to positive"
My car is W202 C200 year 95.
In the first place i sent the ECU to the Mr German because the ECU is faulty (only 2 cylinders work)
Any idea about the error above?
Thanks..
Old May 18, 2006 | 12:24 PM
it means that there is a problem with the signal from RCL control module. (remote central locking).
does the door lock open and close using remote key?
the problem is from IFZ control module. check if has power.
here's a simple test to know if it is getting the signal.
connect voltmeter to ecu pin #1 connector 1 (minus), and pin#12 connector 2.
ignition on.
unlock the door > 4-7 volts
lock the door > 2-4 volts.
either than that... your infrared control unit got problem.
Old May 18, 2006 | 12:57 PM
ibestriker's Avatar
If my infrared control unit got problem, does that mean, I need to send the ECU for repair, again?
Where is the infrared control unit situated? In the ECU or in the car key? Or in the rear mirror?
Thanks...
Old May 19, 2006 | 12:58 AM
you need to tell me the VIN so i will know what kind of components you got.
[IMG]local://upfiles/1/841F17E6FE1F466AA7F4BB1065C1F386.jpg[/IMG]
Old May 19, 2006 | 01:17 AM
ibestriker's Avatar
Hi Sleepwalker,
This is the info:
Model: Mercedes Benz C200
Year: 1995
Tel: Car VIN: WDB2020202F228080
Message: ECU with below details:
- ECU VM Part Number: 018 545 1132
- ECU OE Ref Number: 0 261 200 614
- ECU Type: PMS
Thanks in advance...
Old May 19, 2006 | 01:22 AM
ibestriker's Avatar
From the picture, its like the IFZ Control Module is neither in the ECU nor in the car key.
But it is near to the passenger pedal?
Do you think the control module has something to do with the rear mirror? Should I check it as well?
Do you think I should check the key battery as well? Is there any possibility the remote key battery is weak, and dont have the capability to unlock the immobilizer?
Confused now..
Old May 19, 2006 | 01:27 AM
  #9
was the red and green light blinking alternately or at the same time?
Old May 19, 2006 | 01:35 AM
  #10
ibestriker's Avatar
They blink alternately..:-)
Do u have any idea ?
