What is the Acceleration suppose to be like
I'm new to MB so not sure how to check if my 03 c240 is accelerating properly.reaskn why im asking this is because when i first purchased my Mb it had a problem where it wouldn't move every now and then when ever i came to a complete stop. It came out to be the throttle body, being extremely dirty and was being driven for a while without any maintenance being done to it.so i clean the body throttle and did an engine oil change and changed the filter. As well as the intake filters. So im not sure if when i step on the gas the acceleration is right or to slow but it feels like it should pick up faster.any way i can check that or anything i should change to improve the acceleration. Thank you
Hello and welcome to the forum! You can hook your car up to a code reader and see if any error codes come up. Let us know if you have any other questions.
If you're looking at purchasing one, check out this one - https://www.pelicanparts.com/catalog...STGEN1_pg5.htm
Thank you for the help
I did manage to check my codes on a ODB2 to my surprise i have 7 codes. here they are can someone please explain what pending means
1.PO400 stored
Exhaust gas recirculation flow
2.PO400 stored
Flow
3.PO171 pending
System too lean (bank1)(bank2)
4.PO123 pending
Throttle/pedal position sensor A circuit high input
5.PO140 pending
02 Circuit No Activity Detected (bank1 sensor 2)
6.PO160 pending
02 circuit no Activity Detected (bank2 sensor2)
7.PO221 throttle/pedal position switch B circuit rang/Performance
What should i try and fix first and is it worth putting money into my car. Btw I truly like my car thanks for the help
1.PO400 stored
2.PO400 stored
Flow
3.PO171 pending
4.PO123 pending
5.PO140 pending
6.PO160 pending
jikian
09-11-2019 07:59 PM
Kdinnegan
01-10-2019 01:44 PM
Tom Ellis Gunn
11-20-2017 12:16 PM
