Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
Please help with service and purchase decision
Old Jan 18, 2022 | 08:44 AM
farshschafer's Avatar
Default Please help with service and purchase decision
HI GUYS , I WAS ABOUT TO BUY A USED C200 2015 MODEL SO I DECIDED TO TAKE COMPREHENSIVE TEST TO CHECK VEHICLE PROBLEMS.BASED ON THE REPORT PLEASE HELP ME OUT TO MAKE DECISION TO BUY THIS CAR.
MINOR ENGINE OIL LEAK
ESP(Electronic Stability program -- ( 3 )
U0417FA
Data received from the Electric Parking Brake (EPB) were implausible.
B23AA1D Stored Event
The left brake calliper is faulty. The current value is out of the permissible range.
Stored
C100B77
The Electric Parking Brake (EPB) is faulty. The commanded position cannot be achieved. Stored Event
ISM(Shift module) -( 2)
P179A12
The Direct Select redundancy system is faulty. There is a short circuit to battery(+).
Pl 79DOO
Stored Event
The Direct Select redundancy system was activated.
Stored Event
PSD(Control module for panoramic sliding sunroof) -(1 )
U016887
Stored Event
Communication with the Electronic Ignition Switch (EIS/EZS) is faulty. The message is lost.
Old Jul 24, 2023 | 09:11 AM
MelissaMati's Avatar
Hey there! I know this thread is pretty old, but I just wanted to chime in and offer some advice. If you're still considering the C200 2015 model, it's worth noting that there were a few issues mentioned in the test report. There's a small engine oil leak, some problems with the ESP, Electric Parking Brake, and Shift Module, as well as the left brake caliper and panoramic sliding sunroof control module. Before you make a decision, it might be a good idea to have a mechanic check out the car. They can give you a better idea of the extent of these issues and how much it might cost to fix them. But you know, sometimes heads or tails may help with a decision. Anyway, let us know what you chose eventually.
Chandler
Mar 13, 2018 03:20 PM
starketcher
Aug 9, 2007 09:38 PM
97_230_Carnage
Dec 29, 2006 04:41 AM
my87560sel
Aug 5, 2006 07:49 AM
LIDrummer
Dec 18, 2005 03:24 AM
