Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
1982 240D how do I know if my motor seized
Old Sep 24, 2022 | 12:32 PM
Kramer$'s Avatar
Default 1982 240D how do I know if my motor seized
Seized motor? 82 240D won't bump start batteries good starters good how do I know if the motor seized
Well being pulled home at 55 down the freeway I threw it in fourth gear my tires didn't lock up but I slowed the person pulling me down tremendously and took it out of gear to not destroy their vehicle
It was running fine I stopped at a rest area I tried to start it it was having trouble I think because I'm missing a couple teeth on my flywheel but it always does that and then it just went click I tried jumping the battery I tried push starting it I had someone push me with their truck I can't get nothing to happen I have fuel I'm wondering maybe my injection pump? I need to get this old girl running she's my everyday car
I don't really want to pull the radiator to try to turn it over by hand is there any other way to find out if my engine is seized
Old Oct 13, 2022 | 07:35 PM
Marcianello's Avatar
I dont think a bad injection pump would cause the motor to stop turning over. How do you know the starter is good?
If you have a failed head gasket, the cylinders can fill with coolant and your starter might not be strong enough to turn it (which you don't want to do anyways - water doesn't compress).
Old Oct 18, 2022 | 11:39 AM
DFergusonMB's Avatar
Put a ratcheting breaker bar on the crank pulley and see if you can physically turn the motor over. Best way to determine if it's seized. Diagnose from there.
Kramer$
Sep 24, 2022 12:29 PM
xjvoorheesx
Nov 29, 2006 01:56 PM
Rather Diesel
Jul 9, 2006 12:58 AM
BuyMBparts
Nov 12, 2004 12:16 PM
kymeria
Feb 5, 2004 05:41 PM
