Mercedes AMG Class All AMG Models.
SL55 Brakes
Old Jul 19, 2005 | 02:58 AM
erbasile's Avatar
Default SL55 Brakes
The front brakes dust the wheels 8 to 9 times thicker than the rear wheels. Is this normal? Are there brake pads available that would reduce the dust build up? Can the brake pad pressure be checked to determine if the front and back are getting the correct pressures? I need some background before talking with the MB dealer.
Old Jul 19, 2005 | 04:01 AM
SL600_Cruzin's Avatar
Default RE: SL55 Brakes
Usually the front-end accounts for approx. 75% of your braking power, therefore that's why you see more brake dust on the front than you do the rear. Your front pads will also wear out quicker than the rears because of the same reason.
You can purchase some aftermarket pads that claim they throw less dust, but I've never had any luck finding a set that wouldn't squeel. So for me .. I'll stick with the dust of the OEM pads.
just my .02 cents worth
Cheers
55cs
Apr 20, 2012 07:10 AM
SuperStreetRX7
Feb 7, 2005 01:23 AM
Ingenere
Apr 11, 2004 04:11 AM
GinaK
Feb 18, 2004 06:36 AM
