Mercedes AMG Class All AMG Models.
04 bone stock E55 in Atco Raceway, NJ
Old Mar 28, 2007 | 12:36 AM
2swoosh's Avatar
Default 04 bone stock E55 in Atco Raceway, NJ
took my car to the dragstrip tonight no mods whatsoever and the car did decent.
first run: 12.50 @ 111 mph with 60' of 1.8
2nd run: 14 seconds @ 109 mph (spun the whole 60')
3rd run: 12.68 @ 109 mph with 60' of 1.96
I guess with a small pulley,chip, and a set of MTs drag radial this car could see high 11s?
Old Mar 28, 2007 | 11:04 PM
JOE55's Avatar
Default RE: 04 bone stock E55 in Atco Raceway, NJ
Cool, you got video ny any chance?
Old Mar 29, 2007 | 02:36 AM
2swoosh's Avatar
i wished i had one Joesorry but i'm going to Cecil County in Maryland on Saturday i'll ask some friends to do it for me.
Old Mar 29, 2007 | 03:49 AM
JOE55's Avatar
It's cool, I just thought you have one, good luck on your next run!
Old Mar 29, 2007 | 04:06 AM
chiromikey's Avatar
ORIGINAL: 2swoosh
...I guess with a small pulley,chip, and a set of MTs drag radial this car could see high 11s?
atco is arguably the fastest track in the country so it's entirely possible for you to see 11's without doing anything except perfecting your launch. if not, you won't need drag radials or an ecu tune...a pulley will easily get you there.
Old Mar 29, 2007 | 06:28 AM
OptiCan's Avatar
Cool to see that someone realy like to take the E55 for a ride [8D]
You are correct, new software and/or also a new pulley will improve your numbers. How far down you can get has also some to do with your launch (as mentioned above). I would say do an upgrade in two steps, first only software (check the numbers), then pulley and new software (and check numbers again). I think you would see good improvements in the numbers.
Enjoy the ride
Old Mar 29, 2007 | 03:12 PM
2swoosh's Avatar
i'm gonna try to leave the traction control on next time and see what happens to the 60', i wished there's other fellow Benz in my area to unwind in the track it's fun. Anyway, i'm not sure how strong the driveline (axles, etc...) of these cars, anyone?
Old Mar 29, 2007 | 03:41 PM
chiromikey's Avatar
ORIGINAL: 2swoosh
you definitely don't need to worry about the driveline. the best launch technique is as follows:
1. esp off, transmission in sport mode, and suspension in comfort.
2. drive around the water box and doa quick 2-3 second dry burnout just to lightly warm and clean the tires.
3. do not bring up the rpms or preload the torque converter by power braking. launch from idle by releasing the brake at the same time as you quickly mashthe pedal (not quite a stomp).
if you can perfect this you'll get your best luanch and 60ft times. our cars don't respond as well when you stall the torque converter. if the track prep is poor, there won't be much you can do to improve the launch except use esp or try again another day...but that just means you get to race again and there's nothing wrong with that.
btw, i completey disagreewith getting an ecu tune by itself (sorry optican), there's not enough hp in it to justify the money. in fact, you don't need an ecu tune until you've gone stage 2 (pulley and headers/exhaust) or higher. if you're going to mod, a pulley should be the first stepas it's the best bang for the buck out there.
Old Apr 1, 2007 | 02:39 AM
  #9
2swoosh's Avatar
my trip to Maryland was cancelled due to personal stuff i'll try to go back to Atco on Tuesday and see what happens, thanks for the infos though.
Old Apr 4, 2007 | 01:27 AM
  #10
2swoosh's Avatar
went back to Atco Raceway tonight with a best run of 12.47 @112 mph 60' 1.868 i need to practice more on the 60' as i spun the tires again.
