where is the e 320 trunk light fuse
Old Feb 14, 2004 | 06:57 PM
bobhogan's Avatar
Default where is the e 320 trunk light fuse
Greetings all!</P>
I have an usual situation- my 99E320 was rear ended last night crushing the trunk and rendering it inoperable.I can't get it open no matter what but I can see that the trunk light is on.Where is the fuse for this light, what number socket is it in - I want to pull thefuse on the light so the battery does not run down.</P>
Bob Hogan<IMG src=smileys/smiley5.gif border="0"></P><edited><editID>bobhogan</editID><editDate>38031.7075810185</editDate></edited>
Old Feb 14, 2004 | 11:55 PM
myamg's Avatar
i think it is under the rear set on both sides of the seat bottom on the outer edge there is a little push button, hold the button and push up on the sea and pull </P>
towards the front this will allow u to axcess under the seat on pass side next to battery there is a fuse box and a paper fuse locator it should be on of those when u pull it your inside lights will most likely not work and central locking may not work. good luck</P>
dogman1313
Jun 8, 2011 11:20 AM
tomfer114
Oct 19, 2010 07:26 AM
Wisjd
Feb 1, 2009 12:13 PM
zofitness
Jan 4, 2009 04:16 PM
EdManfredi
Aug 14, 2008 07:01 PM
