water damage? on a benz? what??? help!!
[ol][*]Ok, so i left my sunroof cracked a little bit, we had a down pour, bottomline, i started the car, the gears wouldn't shift, from Park to Drive, i called Service, they advised me to do a manual gear switch, so i did that, then i parked the car, and i tried to start it again, it said "start error" i am very concenred, i hope this did not cause alot of damage, who would of known water damage can be possible on a Benz? i am so stressed i need someone to please help me, the water seeped into where the gear switches, thanks!![/ol]
RE: water damage? on a benz? what??? help!!
Likely your problem is water into the change speed lever CSL mechanism.
This usually occurs due to spilt drinks in the area of the console around the CSL.
Since your water was "clean" i.e. rain you just maybe lucky that things sort themselves out once everything is dry. This may take some considerable time dependent on exactly where / how much water has penetrated the module / wiring.
Unfortunately attempting to use the vehicle (i.e. ignition ON) in the presence of water / moisture can kill the electronic module due to "shorts".
Likely you will need a new CSL module.
Stuart
Stuart
Slick123
06-06-2008 12:24 PM
