Unknown engine Serial number
Old Jun 21, 2022 | 07:49 AM
Lennertvh's Avatar
Exclamation Unknown engine Serial number
Dear All,
I recently bought a land rover series 1 with a non original diesel engine in it. The seller told me it was a mercedes diesel engine.
I was wondering if anyone could help me track down the engine serial number, to determine what kind of engine it is, and if it has any value.
It is a 7 digit serial number starting with 7005xxx.
Is anyone familiar with this code? its probably from an older diesel engine, as it is fitted on a gearbox from 1971.
Thanks in advance.
Old Jun 21, 2022 | 09:16 AM
DFergusonMB's Avatar
https://www.autohausaz.com/tech-tips...cation-numbers
https://www.mbspares.com.au/Informat...isnumbers.aspx
These links should help. Should be able to find the engine code on the side or rear of the engine block, likely parallel to the firewall and/or above the bell housing.
Old Jun 21, 2022 | 10:13 AM
Lennertvh's Avatar
Thank you for your fast response,
I managed to find the engine code, it was on the front right side near the exhaust manifold. however I cant find what type of engine it is, and for what vehicle its made. the number is: 7005385
Old Jun 21, 2022 | 10:45 AM
Anything on the engine that looks like these plates? I'm pretty sure there's gotta be more to that number.
mussonor
May 12, 2012 06:58 AM
tapmemp
Dec 17, 2007 04:04 PM
PHILOGTI
Jun 23, 2005 05:25 PM
psychpw
Jan 15, 2004 07:12 PM
