trunk wont open..central locking failure
Old Jan 14, 2008 | 11:54 AM
johngarcon's Avatar
Default trunk wont open..central locking failure
hi there, hope there is someone that can help with my 1998 slk .
i have encountered a problem with the central locking and i need to get in the trunk to check the pse pump connections as i think water may have got into it (not sure). the central locking has failed with the trunk locked and have just discovered that both my keys will not fit the lock.my doors and fuel flap have remained unlocked.is there any mechanical release or will my local mercedes dealer be able to help.
thanks, john
Old Jan 14, 2008 | 08:41 PM
sleepwalker's Avatar
Default RE: trunk wont open..central locking failure
you might be using valet key.
if you will slightly bring the top down, the trunk will open itself... that's the first thing it will do before stowing the hardtop inside the trunk.
Old Jan 15, 2008 | 07:33 AM
johngarcon's Avatar
hi. yeah i thought of doing that, but because the cover in trunk is not pulled over the roof wont budge. looks like i may have to force the lock somehow. thanks for your reply, john
dee2000
Jul 21, 2011 07:43 PM
delboy277
May 12, 2009 05:19 AM
dgrover
Sep 3, 2008 08:47 AM
fourstake
Aug 26, 2008 04:35 AM
arsinal4496
Nov 18, 2007 02:25 AM
