trunk is closed, but alarm rings and bell rings while i drive
2002 CL500 - my trunk is closed but the trunk open bell rings constantly when i drive and i can't lock the car because alarm will ring ( i assume it thinks someone is opening trunk). is there some loose ground wire? does the mechanical trunk latch need to be replaced? is that hard to do?
thank you. |
could be the latch or the stiker might need to be adjusted.
thank you much, i guess i'll try to replace latch. . . .
