trans fluid being sucked into the combustion chamber
Old Jul 26, 2008 | 10:16 AM
ralphster's Avatar
Default trans fluid being sucked into the combustion chamber
can a bad vaccum module let trans fluid get in the motor through the vaccum line
Old Jul 26, 2008 | 11:10 AM
AMGMercedes's Avatar
Default RE: trans fluid being sucked into the combustion chamber
Yes. And when you go to change it, replace the inner plastic piece because it's likely broken or will break. I forget what it's called.
flainn
May 2, 2012 10:55 AM
Benzmama
Sep 12, 2009 07:44 PM
MOVIS
May 8, 2009 04:41 PM
ralphster
Jul 26, 2008 09:40 AM
WB9AXO
Dec 15, 2006 04:58 PM
