Traction problems on 2002 class C
Old Aug 7, 2007 | 06:42 AM
jpsa's Avatar
Default Traction problems on 2002 class C
Hi there!
My 2002 class C sportcoupe(and all others I guess) has a serious traction problem due to the open differential. This is most critical on 2 situations: when 1 of the wheels is on ice and the other on tarmac, and when getting out of a garage that has a curve in the middle on the ramp. In these 2 situations, one of the wheels starts spinning hopelessly, leaving me stuck without moving... the esp can't do anything to help.
On the other hand my father's class E (2005 I think) doesn't do this, I think the esp senses the spinning wheel and brakes it so that the other wheel gets going.
Has this happened to any of you?
Is there anyway to fix this problem? Like a esp update maybe?
Cheers!
Old Aug 15, 2007 | 09:44 PM
MBTECHINFO's Avatar
Default RE: Traction problems on 2002 class C
Unfortunately, there is no update availible for the early 203 c class. The traction system is different than on the E class. The E class is equipped with the SBC hydraulic unit (AKA brake-by-wire) that has esp incorporated into the unit and has been further refined and can easily isolate individual brake circuits on each individual wheel to match wheel speed without using the brake. There is nothing you can do other thanmake sure that you have good quality tires.
Eyad12
Jul 4, 2012 01:39 AM
mharnouski
Jun 19, 2005 08:45 AM
chairman4u
May 1, 2005 07:35 PM
McMucker
Mar 2, 2005 11:20 AM
stimike
Nov 27, 2004 07:58 AM
