THUMP WHEN TAKE-OFF
Old Oct 3, 2006 | 08:12 PM
PLYRHATR's Avatar
Default THUMP WHEN TAKE-OFF
Hey fellas, can any one of you guys help me out. bought a used 99 e320 that was hit in th epast. body work had been repaired but prior to me buying it. dont know the history and the prior owner is no help. my problem is that when i accelerate at a high speed, i feel a thump and it stays continuous until i slow down or coast. it feels as if the strut moves or the rack and pinion rotates a bit. it only happens when i accelerate or turn left at a high speed. if i casually speed up or turn at a low speed, you'd never know there was a problem. i got under the car and everything looks fine and tightened down, except the tie rod end on the drivers side coming off of the rack and pinion. there seems to be a lot of play and the bushing is in need of replacement. can anyone help me out before i take it to the shop and pay for their estimates. would a tie rod end cause this "grinding noise" or thump? any help or suggestions would be greatly appreciated. thanks.
Old Oct 4, 2006 | 12:04 AM
itrdreams's Avatar
Default RE: THUMP WHEN TAKE-OFF
check three things,
First take a look at your exhaust heat shields. see if any of them are bent or too close to the exhaust piping.
They should have at least 4" space between them.
2nd: look at your plastic splash shields. they can also cause this noise.
3rdlook at your motor mounts. dont forget your trans mount if it looks like it is sagging replace it.
Even though it is not completely broken it still can cause problems.
Old Oct 4, 2006 | 04:12 PM
PLYRHATR's Avatar
THANKS FOR THE ADVICE. IM DEFINITELY LOOKING AT THE DIFFERENT IDEAS YOU GAVE. IT DIDNT EVEN DAWN ON ME ABOUT THE MOTOR MOUNTS AND TRANNY MOUNTS. THANKS!!! I'LL TAKE A LOOK THIS WEEKEND AND UPDATE. THANKS AGAIN.
photosbyisaac
Aug 25, 2009 09:20 AM
sjbug
Jan 18, 2009 06:01 PM
blocke
Nov 14, 2008 05:27 PM
sophiedog
Oct 24, 2006 10:05 AM
RVR
May 1, 2006 06:19 AM
