stumped ??
Old Nov 6, 2008 | 04:55 AM
Courtice_m's Avatar
Default stumped ??
[8D] 05 C230K very slow parking lot speed during a turn.go to accelerate and there is NO RESPONSE no matter how far you depress the accelerator,,THEN if you back off the pedal and try again=AWAY it goes..any sugestions greatly appreciated.
Old Nov 6, 2008 | 10:55 AM
snanceki's Avatar
Default RE: stumped ??
Your car (like many others)( has an electronic accelerator (Fly by wire)
It would appear that there is either a bad connection or alternatively the pedal potentiometer or throrttle actuator component has failed. Usual failure is at high e.g. 100k mileage.
Check out the connections / multi connectors. Loose? Damp?
If no obvious reason can be found maybe best to get the diagnostic codes read. However since fault is intermittent no codes may be stored.
Stuart
Old Nov 6, 2008 | 05:13 PM
Courtice_m's Avatar
thanx for that info,will certainly check it out OR have local MB dealer check it out as i did purchase an extended warranty
hawaiianbio
Jun 1, 2013 09:48 PM
wade1021
Sep 12, 2010 06:01 PM
pllogan
Jan 19, 2009 04:16 PM
motoxnut67
Jun 14, 2008 04:46 AM
Goldenvoice
Aug 4, 2006 12:28 AM
