Start problem
Old 02-07-2006, 11:08 PM
560SSEECC's Avatar
Default RE: Start problem
Thanks a lot. I will try to do so tomoorow. Now i have to sleep. It is 3:05 AM and i need some sleep.Thanks again.
  #12
Old 02-07-2006, 11:10 PM
560SSEECC's Avatar
And idle speed is OK
  #13
Old 02-08-2006, 07:01 AM
560SSEECC's Avatar
And to simulate more than -5 degrees how strong resistor do i have to attach ? More or lesss than 7500 ohms resistor.Do i have to think on the wire colour of the sensor ?
  #14
Old 02-08-2006, 09:28 AM
sleepwalker's Avatar
about 300 ohms for 80 degrees.
any sides because it's resistor and not diode.
  #15
Old 02-08-2006, 06:01 PM
560SSEECC's Avatar
And now something elce. When i pull out Spark Plug Connector and insert another spark inside , then starting the engine , no electicity is to see. Normaly it supouse to be but not in my catse. Therefore some part is not giving some signal to ignition to give electicitu. Is it possible that the reference sensor is bad, or the crankshaft position sensor , or elce
  #16
Old 02-09-2006, 02:42 AM
yes.
  #17
Old 02-09-2006, 04:44 AM
560SSEECC's Avatar
Where is positionated this crankshaft position sensor. Any photo. And if this sensor bad is how is it possible that i can start the engine at minus dereees. Hm... Thanks
  #18
Old 02-09-2006, 05:02 AM
560SSEECC's Avatar
[IMG][/IMG] some pictures
  #19
Old 02-09-2006, 09:17 AM
ORIGINAL: 560SSEECC
resistance changes with temperatures.
most of the sensors are resistors.
  #20
Old 02-09-2006, 04:52 PM
560SSEECC's Avatar
And can i drive the car if i put 7500 ohms resistor at the temerature sensor ? Any damages after ?
Quick Reply: Start problem
