SLK Boost Problem
Old Mar 31, 2005 | 01:51 AM
mbfaster's Avatar
Default SLK Boost Problem
'99 slk seems to have lost power. It is acting like any normal car that doesn't have a supercharger in that it will accelerate, but not as quickly as if a supercharger was present. Have checked to see if clutch engages on the supercharger when under load and it does. ECU has just been replaced as they thought it was the culprit and it wasn't. Ran the OBD and it comes back clear. No check engine light. Is there something else I should look for before I bring it back in to the tech?
Old Mar 31, 2005 | 04:31 AM
sleepwalker's Avatar
Default RE: SLK Boost Problem
test the secondary air injection. with engine running at 3000rpm, turn it on and you will hear that big whine from the engine.
Old Apr 1, 2005 | 12:23 AM
mbfaster's Avatar
Hi sleepwalker, thanks for giving me a hand in this. Where do I look and how do I turn on the secondary air injector? What should I be looking for?
Old Apr 1, 2005 | 12:40 AM
make a jumper on the secondary injection relay.
Old Apr 1, 2005 | 01:37 AM
mbfaster's Avatar
Ok, will give that shot. Is there an engine schematic somewhere on the web that you know of. Hunted for one for a couple of hours, but the sites keep directing me to used car parts.
Old Apr 24, 2005 | 08:29 AM
bazzle's Avatar
How do you check the clutch conmes in under load??
Mine has similar symptoms today [&:]
Thanks Bazzle
farky
Apr 19, 2012 12:20 PM
davesdiesel
Jul 18, 2007 02:42 PM
jpbcp
Apr 30, 2004 10:53 PM
Asild
Mar 9, 2004 03:42 AM
imi-amg
Aug 29, 2003 08:23 PM
