ruff Idle start up
Old May 10, 2004 | 05:06 PM
rcnmn77's Avatar
Default ruff Idle start up
I just bought a 90 560 SEL When I start up cold just turn the key she fires off no problem but I notice a little ruff and the rpm are low about 500 and then she gradualy smooths out within a minute of run time and the rpm go to about 650 is this normal I would think that engine would start at higher Idle when cold and then drop down to normal after warming up, this is all without touching the excelerator pedel any suggestions
Bob
Old Jun 16, 2004 | 12:29 PM
rcnmn77's Avatar
Default RE: ruff Idle start up
Ok I found what the problem is. When I change sparks plugs i noticed one of the plugs were a little wet with fuel so I proceeded installing new plugs but this did not solve the idle problem. I then proceed to change out the injector for the cyclender that had the wet plug this made and improvement not as ruff and then proceeded to adjust the fuel/air mixture setting and the engine smooth out,like a rock. Now when I start the engine the rpm's go to 1200 and then slowly back to 650 and the Idle is smooth.
Bob
Old Jun 17, 2004 | 12:16 PM
sleepwalker's Avatar
good job.
the engine is not ruff anymore even without touching the excelerator pedel. the cyclender now runs good.
C2801331
Nov 29, 2010 09:01 PM
crxtrixxx
Feb 19, 2008 08:34 PM
paypaboi
Apr 2, 2007 08:46 PM
ATMmacheen
Oct 22, 2005 04:11 PM
clkgeorge
Jun 22, 2005 12:59 AM
