Rough Running
Old Oct 27, 2006 | 11:48 AM
hasbenz's Avatar
Default Rough Running
Have a 1995 SL 500 that suddenly has little power, rough idle, hard shift - Check engine light.
Any suggestions: Vacuum or Mass Air Flow?
Old Nov 2, 2006 | 02:58 AM
kurt08's Avatar
Default RE: Rough Running
You may try a MAP relocation kit to remedy rough idle. Try disconnecting the EGR backpressure transducer from the vacuum lead and check if it alleviates the problem. Your EGR valve may have rusted or stuck open.
alchan
Apr 6, 2014 08:24 AM
Jinxie
Jan 22, 2005 11:55 AM
97420mb
Nov 13, 2004 09:43 PM
TajA
Sep 25, 2003 01:52 PM
