resting?
Old Nov 7, 2006 | 05:47 PM
marshman's Avatar
Default resting?
i just buoght a 2002 MB C240 and the winsheld washer fluid keep on poping up on my dash i cant reset it,and it didnt come with a owner manual,any idea?
Old Nov 7, 2006 | 06:18 PM
mbz300sdl's Avatar
Default RE: resting?
Get an owners manual look on ebay they normally have them for almost any car. I got one off there for my audi.
Old Nov 8, 2006 | 02:58 AM
snanceki's Avatar
Auto reset so long as the Washer bottle is replenished. I assume this is the case.
The washer bottle has a sensor to determine fluid level. If bottle is full you need to access the washer bottle and inspect sensor. It could have backed out of the hole in the tank, wires come off etc. Not sure if it is located beneath the wheelarch (above liner) or is more readily accessible in your model from the engine compartment.
Old Nov 8, 2006 | 07:40 AM
marshman's Avatar
ok thanks! im gonna take a look.
Old Nov 24, 2006 | 05:45 AM
marshman's Avatar
i check the sensor and it still came on,i also notics that there are 2 plugs disconnect near the reservor.
Old Nov 24, 2006 | 07:35 AM
snanceki's Avatar
Sure they aren't the sensor wires?
What are the colours of the disconnected wires?
Stuart
Old Nov 26, 2006 | 09:14 PM
marshman's Avatar
not sure if its the sensor wire cause it is still hooked up to the bottle there is 2 of em that is unplug that i dont know were it goes.
Old Nov 27, 2006 | 02:58 AM
snanceki's Avatar
The washer bottle has wires going to the pump and to a sensor.
If the pump works when you clean the screen the disconnected wires must be to the sensor.
If you get low warning of fluid level this is because you have low water level, your sensor has gone bad or the circuit is bad (ie disconnected)
Not sure how else I can help.
Stuart
Old Nov 27, 2006 | 08:14 AM
  #9
marshman's Avatar
thanks,i think im gonna try and clean the sensor mybe that might help if not how much is it for a new sensor?
Old Nov 27, 2006 | 08:39 AM
  #10
sleepwalker's Avatar
just reset it with the trip odometer button.
fill the washer fluid.
