Replacing Voltage Regulator (R230 SL)
I have a 2006 SL500 so this question applies to 2003 and newer SL's.
I have spent about 40 minutes trying to find instructions on replacing a voltage regulator on a R230 SL500 with no luck.
Does anyone know what's involved in replacing the voltage regulator on a R230 SL? Does the alternator need to be pulled to replace the regulator? Can it be done from above or below?
Also, when I talked to a Mercedes' Tech he said my problem could be caused by a faulty "charge control unit" which applies power to the battery that is weakest."Does anyone have a clue about this charge control unit?
Thanks in advance.
Thanks in advance.
widmer
10-15-2006 10:07 PM
widmer
09-24-2006 10:43 PM
