Reading codes
Old Nov 21, 2006 | 08:14 PM
Daryljames101's Avatar
Default Reading codes
Hi All,
I've got a 1994 E420. I was shown how to retrieve the codes for the check engine light. Does anyone know of where I can retrieve the info on how to calculate what they mean?
Old Nov 22, 2006 | 10:34 PM
lsboogy's Avatar
Default RE: Reading codes
Hi - if they are OBDII codes - I can probably tell you what they mean - do you know the numbers?
Andrew
Old Nov 30, 2006 | 01:28 AM
I held down the red button in the sequence of 3 seconds then 8 seconds, the light gave me three codes 9 flashes, 17 flashes, and 3 flashes, does that make any sense?
Old Nov 30, 2006 | 02:41 AM
Qamar's Avatar
http://auto-diagnostic-codes.com/
Just click on the above link and enjoy.
Take care
Old Nov 30, 2006 | 05:25 PM
The only code i could get to come up was 9 and it said that it was a transmission valve block- malfunction. is that good?
Old Dec 2, 2006 | 05:50 PM
Qamar's Avatar
9) Starter signal or pressure actuator
17) Throttle switch - idle speed control valve, CAN signal for BOSCH LH4.1 ECM
3) Coolant temperature sensor (CTS) 2 or circuit
I have E320 1995 model. I presume your car is also having the same connector which is in my car. So the link which i have given above shows the above problems in your car. (As you had mentioned aboout code number 9/17/ and 3)
Old Sep 19, 2008 | 09:00 PM
illybklyn1's Avatar
what's up sure don't but if any one knows the code to start the radio please respond!
E420 1997
toto
Sep 17, 2009 08:04 PM
Pverduzco
Aug 31, 2009 10:15 PM
seblani
May 23, 2008 01:34 PM
seblani
May 22, 2008 08:39 PM
mowog
Feb 20, 2004 06:46 PM
