RE: electric window prblems
Thanks for the schematics on the window system (260E). They helped me to determine that the left front window lift has an open circuit in the motor itself.
The R/H rear also shows an open circuit from the drivers control switch. I suspect that motor may also be bad. What kind of history have you all noticed on these motors? Pretty reliable, or troublesome? Also, what kind of cost should I look for in replacement parts? I may be better off finding an entire Left front door assy(the old one is rather beat up), since the hold open assy is also broken off. What kind of cost would that run?
