Psycho power seat in a 2000 CLK320
Old Feb 22, 2008 | 07:49 PM
j28161's Avatar
Default Psycho power seat in a 2000 CLK320
Help, the car seat is possessed. The driver seat moves forward when you push the button forward, then it moves forward when you push the button back. The only way to get it to move back once you move it forward is to use the seat memory. Also, the thigh adjust does the same thing. It only goes up. If you push down, it still goes up, but again, if I use the memory, it will go back down to the memory position. I would love to fix this but don't know where to start. Any help would be much appreciated.
Old Feb 22, 2008 | 08:16 PM
tmimb's Avatar
Default RE: Psycho power seat in a 2000 CLK320
The seat memory has been lost in the motor. run your seat all the way forward and it will then relearn itself. I've seen this a few times. If you have to use the memory button to get it to go where you want it after that you may need a switch. Do the same for up down.
Old Sep 23, 2008 | 12:08 AM
MBTECHINFO's Avatar
MOVE THE SWITCH RAPIDLY IN BOTH POSITIONS UNTIL IT STARTS WORKING LIKE NORMAL. THE CONTACTS COMMONLY GET STALE AND THIS WILL AID IN CORRECTING PROBLEM LIKE 80 PERCENT OF THE TIME.
cbwhitley
Oct 30, 2012 12:08 PM
I love the PCH
Jul 1, 2011 10:13 AM
elmwood
Dec 11, 2009 02:41 AM
2000clk320
Dec 11, 2006 06:19 PM
2000clk320
Apr 20, 2006 09:42 PM
