POWER STEERING NOISE
Old Jul 4, 2007 | 05:45 AM
Year1998C200's Avatar
Default POWER STEERING NOISE
Hey,
i have a yr1998 c200....in the morning when i start the carthen i turn the steering either side i get a funny loud noise (kinda likea screech)..the idling is also a bit high. after i drive the car for like ten minutes it dissapears. what could it be?
Please Help
Old Jul 4, 2007 | 08:25 AM
SunGuy62's Avatar
Default RE: POWER STEERING NOISE
Hey,
Did you check the PS reservoir for fluid level? Drive belt slipping on the pulley at the PS pump?
Bob
Old Jul 4, 2007 | 11:40 AM
bob
i checked the ps fluid level and it was below minimum. let me add fluid and check how it behaves
Old Jul 4, 2007 | 11:44 AM
SunGuy62's Avatar
If you're adding fluid, you've got a leak somewhere. Check around the hose fittings below the PS pump and the fittings at the steering box. You may have to remove some items to find where this fluid is going.
Bob
Old Jul 5, 2007 | 04:43 AM
snanceki's Avatar
A screech at FULL LOCK is not unsual and can be due to a loose drive belt but the MB system is not usually prone to this.
Maybe your screech is a "swisssh" which could easily be due to low PAS fluid level.
First step check fluid level. Ensure you use the correct marks dependent upon whether hot or cold (fluid not ambient)
If OK then check condition of the drive belt and tensioner. Oil contamination o0n belt?
If it only occurs at full lock and only when COLD I would suggest you accept the noise as a "feature" of the system.
Stuart
Old Jul 5, 2007 | 07:38 AM
hey bob/stuart
thanks a lot. it was the PS fluid. i do have a slow leak somewhere. i added and the noise stopped.
icedenali
Sep 22, 2009 12:18 PM
AMGMercedes
Apr 2, 2007 10:49 PM
vasputin
Mar 7, 2007 01:45 AM
e430dude2
Feb 18, 2007 09:15 AM
Taddub
Jun 10, 2004 10:55 AM
