power seats and windshield wiper don't work
Hey Folks,
Does anybody have a fuse box diagram for a '86 300 e??? mine doesn't have it and need to check the fuses for a little problem that I have. The power seats don't work unless the door is open, and today found out that neither the windshield wiper or the high beams (when your lights are off but you pull from the wiper, left, and right turn signal stick and the high beams should turn on). Haven't checked if the power windows work.
Can anyone tell me if most likely it's a fuse, or a relay problem, or should I just not bother and go to the dealerdhip to fix it??
Thank you.
Thank you.
Problem fixed. It was wierd coz I went over all the fuses and relays when I got off work but the wiper and all the other stuff would not work. Then when I got home checked the fuses again and voila!!!! everything works fine.
