please help how to remove the lower control arm front bolt
hello guys,
as some of you know that i hit a pathwalk and i bent some front end parts on the front driver side.. now i ripped upart to replace the front left control arm assembly on my 190E 1990. i alrwsy took the rear bolt and nut and the bolt and nut tha connects the ball joint with teh spindle, now i am having hard time to take out the bolt for the front of the arm,,, i already have losen the nut but the bolt doesnt even move left or right and i tried anything i could with an 22mm socket and praybar pushing , it wont move.. please help what should i do i need to put my car back together before saturday, i cant even put the wheel on becuse as 2/3 of the control front left arm is out.. i also am including some pictures of what i am talking about..
[IMG]local://upfiles/7055/04BC131F502C46ACA0DA13D95427588C.jpg[/IMG]
[IMG]local://upfiles/7055/F320285A73AC448AB9A1894C70CD4A11.jpg[/IMG]
[IMG]local://upfiles/7055/20090DBD87024A74B350F1945AB173E0.jpg[/IMG]
it's seized because i can see rust even from outside.
try turning that bolt several times before pushing it out with a punch and heavy hammer.
[IMG]local://upfiles/1/F5905A51A380450BAB1352DF5C33254D.jpg[/IMG]
hey sleepwalker,
thanks for repling to me , i already have tried that , i have put all my power in there trying to hit the thing and trying to move it with the socket , but wont move at all..[:@].. what else i could do to it ..?? please help.... thanks
adi
adi
some more pics
[IMG]local://upfiles/7055/82414CF9FE2F4DAEB1480785FD4CBAB5.jpg[/IMG]
[IMG]local://upfiles/7055/07D1E2BADE804AD8BAAF148681A125DF.jpg[/IMG]
it's just seized.
have you tried spraying with lubricant overnight? penetrating oil is good.
find a strong socket for that bolt, then an extended handle where you can gain more lever. it has to turn, there's no way it can't.
Difficult to add to what Sleepwalker has already said but just in case it helps.....
You say you have already loosened the NUT. Which end did you turn to loosen the nut?
The nut shown in your photo is a special cam adjusting device (cam washer is welded to nut) which permits geometry to be set by turning the nut, which reacts against the two metal abutment walls also seen in the picture.
I suspect that you have just managed to turn the NUT rather than the BOLT.
Using a single hex socket (gives better engagment than a 12 point, so will reduce the risk of damage if it is really tight) undo the BOLT (end not in the picture). The nut has a convential thread so you will need to turn the BOLT head anticlockwise when viewed from the head end.
Once you have managed to turn the BOLT there should be no great difficulty in getting it to come out with the help of a hammer and drift, since any corrosion between the bolt and the inside of the rubber bush tube will have been broken.
If its very tight get the penetrating oil out and leave for an hour or so before attempting again.
If you are still stuck get an impact tool (like they use on road wheel nuts at the tyre shop) to encourage the bolt to turn.
If you really can't get the bolt to turn you are going to have to drill it out.
Good Luck.
Good Luck.
philipk2003
Dec 8, 2009 12:11 PM
jano
Sep 9, 2009 10:05 PM
Benz_190
Mar 10, 2006 02:12 PM
