Performance Brakes
Old Aug 30, 2003 | 03:57 AM
PeetaGTS's Avatar
Default Performance Brakes
Hey guys, new to this forums.. i just had a question,</P>
I am planning on purchasing Bremobo Brake Rotors and Pads for my 2001 SLK and would just curious about the snsors for the brake rotors... mercedes have a sensor ont he brakes that tells you when the brakes needs to be replaced... if i purchase and install the brembo brake rotors and pad.. will the sensor still work? Thanks for your help</P>
Old Jul 15, 2008 | 05:34 AM
kurtdaniel's Avatar
Default RE: Performance Brakes
ORIGINAL: PeetaGTS
I am planning on purchasing Bremobo Brake Rotors and Pads for my 2001 SLK from Autopartswarehouse.com and would just curious about the snsors for the brake rotors... mercedes have a sensor ont he brakes that tells you when the brakes needs to be replaced... if i purchase and install the brembo brake rotors and pad.. will the sensor still work? Thanks for your help
This little mod will make the sensors fails. I will no longer warn you when your brake pads are about to wear down.
Cal44DE
Jun 9, 2004 01:38 PM
jpbcp
Apr 30, 2004 10:53 PM
sig55
Jan 27, 2004 01:07 AM
Burley1
Dec 4, 2003 02:29 AM
FerdieC230
Jul 9, 2003 06:47 PM
