Oil leaking through Cam Shaft Position Sensor?
Old Jan 18, 2020 | 10:13 AM
c3incjjc's Avatar
Default Oil leaking through Cam Shaft Position Sensor?
I was told that oil was leaking through my cam shaft position sensor and into the wiring harness. Told we would have to replace 4 sensors and possibly the wiring harness if we didn't fix immediately. They said that oil leaking into the wire harness might cause a short and if that happens we would have to replace the entire harness. IT THIS TRUE? IS IT POSSIBLE? Can the oil really get into the wiring harness?
Thanks appreciate all input
c3incjjc
Nov 20, 2020 11:06 PM
c3incjjc
Jan 11, 2020 01:43 PM
Gene Moses
Dec 23, 2016 02:21 AM
ciaranb
May 21, 2008 02:34 AM
thegirlilove
May 2, 2005 10:57 AM
