New here; need help - serious
Old Oct 5, 2010 | 02:38 PM
pdmsam's Avatar
Default New here; need help - serious
1995 SL500. Changed plugs. Changed oil. Drained and flushed coolant system. Replenished and trouble started.
However I am not sure it is related to coolant. Here is the situation. Moved to WV. Noted for high ethanol content.
Now; drained, flushed, replenished coolant and vapor came from exhaust. Started running rough and progressively worse until backfire and no run. All the while a vapor (hard to tell if it was antifreeze or sulphur content; it it was white and disappeared 5' away). It had an odor I couldn't identify. But and maybe a whiff of sulphur and/or anti-freeze?
Would be catalitic converter be plugging. Removed spark plugs and no watere blew out and plugs weren't wet and no water in oil.
Anyone with ideas? Thank you. pdmsampickens at gmail com
Old Oct 5, 2010 | 06:41 PM
waybomb's Avatar
Is your coolant level dropping? What about transmission fluid level?
Old Oct 6, 2010 | 08:42 AM
pdmsam's Avatar
My thinking is Ethanol and clogged cat converter. Coolant level great. But, have not checked trans level. Seems this ethanol gas is causing problems in everything I own and my buddy too. I've had to put exxon prem in my van w/lucas gas treatment and replace cat covert to resolve its problem.
Would trans fluid get into exhaust?
Thanks.
Old Oct 6, 2010 | 08:55 AM
waybomb's Avatar
I am not certain your car has a vacuum modulator on the trans, but if it does, the diaphragm inside could be broken, and engine vacuum sucking trans fluid into the intake. Burned trans fluid makes white smoke.
Old Oct 6, 2010 | 10:09 AM
pdmsam's Avatar
Tran fluid is low? Path to exhaust? Ideas?
Old Oct 6, 2010 | 10:12 AM
pdmsam's Avatar
Thank you so much: yes, white smoke is coming out the exhaust. I can't identify the smell. Will this also messup the O2 sensor requiring its replacement?
waybomb's Avatar
Did you see my explanation above? If your trans has a vacuum modulator, it is possible that engine vacuum is sucking trans fluid through the vacuum tube, into your intake, and is being burned with the fuel. This would be most notocable at idle, at deceleration, or any time you have high engine vacuum
Old Oct 6, 2010 | 12:31 PM
waybomb's Avatar
IF you have a vacuum modulator on your trans, pull the hose off at the modulator - if it is bad, oil will come out of the hose. That hose should be clean and dry on the inside.
Old Oct 6, 2010 | 07:04 PM
  #9
pdmsam's Avatar
Thanks a lot; this is a ton of help. Will advise of outcome.
Old Oct 6, 2010 | 08:25 PM
  #10
waybomb's Avatar
Yes, please.
whoddinni
Apr 25, 2009 03:38 PM
MB 560sec
Apr 1, 2009 02:10 PM
BlueSilver
Jun 6, 2007 08:22 PM
560SEL
Jan 30, 2006 04:58 PM
doucy2
Jan 23, 2006 03:01 AM
