My 79 4540SLC engine is running between
Old Nov 14, 2005 | 10:19 AM
C280 wizard's Avatar
Default My 79 4540SLC engine is running between
175 degrees and 200 degrees when driving, usually the temp is toward the low end, but will shoot up to 200 degreesF if I let it idle for a few minutes. MY temp gauge is in F by the way. What is the "normal" running temp of these engines. The owners manual and shop manual are both vague on the subject except if the temp gauge goes into the red.?
Thanks!
Old Nov 14, 2005 | 02:40 PM
Lugnut's Avatar
Default RE: My 79 4540SLC engine is running between
That sounds normal. I don't know what it should be exactly, but I would guess it has a 180* or 190* thermostat. Running up to 200 during idling won't hurt anything, especially if comes back down when the car moves.
Old Nov 15, 2005 | 02:26 PM
Yes, it does come back down to between 175 degrees and 180 degrees F. thanks!
axel_g
Nov 7, 2011 06:41 PM
darkmoebius
Jun 22, 2006 04:08 PM
chavez
Dec 4, 2004 03:35 AM
slowtan
May 29, 2004 09:58 AM
dimple212
Feb 14, 2004 05:42 AM
