ML500: P0335 Crankshaft Positon Sensor CIRCUIT malfunction
Hello;
I have a 2002, ML 500 about 77,000 miles on it. The car was switched of for about 4 hrs.
I tried to start the car. Dd not start.
the car was trying to start.. (ost clicking phase).
The auto mechanic tried to jump start it and tried to turn the key about 20-30 times with Gas pedal push.
Finally the car started. but immedialtely after the car started I got this
P0335 Crankshaft Positon Sensor CIRCUIT malfunction error in the check engine light.
Is this a real issue or just a result of something else.
Thanks.
Thanks.
Definatley the crankshaft angle(position) sensor, change it for a new one. It's a bit of a tight space on the C320 saloon. I've just done mine today. Looking good so far. It's a cheap part and if your handy it's not a real problem to change yourself. As the previous reply, it sits at the rear of the engine. just off top dead centre.
good luck!!
good luck!!
1.How much does a Sensor typically cost.
2. The code said it was SenSor A. Should I just change sensor A or should I do also change B too.
3. If I want to do it myself.. can some one point me to some instructions please.
thanks.
thanks.
fraguada1
Apr 14, 2009 10:31 AM
mrrock00
Mar 8, 2008 02:53 AM
jmcclain60
Jan 24, 2006 07:40 PM
