ml320 parking brake
You can also remove the rear wheels and adjust the star wheel to tighten or slacken the ebrake, through the lug bolt holes using a small flat head screw driver or appropriate tool. I think also there is an adjustment above the driveshaft under the car..not totally sure if this car has that design or not. But normally adjusting the star wheel will take care of your issue.
mouratos1a
Nov 2, 2009 04:20 AM
