Mercedes ML 320 summer vs winter
Old Oct 9, 2015 | 12:59 AM
Midnitereign's Avatar
Default Mercedes ML 320 summer vs winter
I bought my car from a private owner that said there is some switch or lever in the engine that has to be moved from hot weather to cold weather. I've never heard of such a thing and can't find anything about it on the Web. I tried to use my defrost for the first time and it's just blowing cold air and he said that's why. Does anyone know about this lever? It's a 1999 ML 320
Old Oct 9, 2015 | 06:25 PM
Originally Posted by ForcedInduction
There is no such thing. Its probably something the owner hacked into the car's heater hose to compensate for a broken heat control valve.
Its likely that opening the valve will also prevent proper operation of the A/C system due to unrestricted coolant flow to the heater.
If you can post a picture of the engine bay we might be able to see it and point it out for you. Depending on what he did to it, we should be able to figure out what needs to be repaired/replaced to restore correct automatic operation.
Yeah, there are A/C issues. It worked when I first got it for about 2 months. He told me he just had it charged a couple months prior. So that sounds feasible. I'll try and get a picture for you. Thanks for the reply.
PelicanParts.com
Jul 6, 2015 02:01 PM
Hot_Rod
May 1, 2008 08:58 PM
shelleE55
Apr 30, 2007 01:21 PM
RoosterBoy
Dec 18, 2006 09:15 PM
AMGDragon
Jun 18, 2005 12:34 AM
