M120 flexplate with 60-2 trigger for VR, where can I find one??
Old Oct 11, 2014 | 04:13 AM
Borgli's Avatar
Default M120 flexplate with 60-2 trigger for VR, where can I find one??
Hi!
I have a 6.0l V12 that I think is from 94 or 95. It has a flexplate with three large arches for the VR sensors. I am replacing the stock ecu(s) with Ms3-pro after the harness cought fire. Trouble is that I need a flexplate that has a 60-2 trigger instead of the three arches. So far, after two days of googling and calling part stores, all I've been able to find is one picture of it from a forum where a guy did exactly the same as I am doing now. The only difference is that his engine came with the 60-2 trigger stock. I've tried contacting the guy, but the thread is from '11 so I'm not sure if he still uses the account.
Do any of you know where I can get a flexplate like that? One would think they would be available, if only a small supply, because they can break/crack.
The diameter of the current flexplate is 12 5/8 inches or ~320mm.
Thank you!
- Runar
Bobs380sl
May 13, 2011 08:05 PM
Bobs380sl
May 11, 2011 07:30 PM
jwrape
Nov 17, 2008 03:27 PM
MATINO
Jul 18, 2007 12:29 AM
sassfactor4
Jul 1, 2005 11:37 AM
