Looking for help 380sl
Guys/gals, I posted in the SL forum looking for some help before I have to have it towed 70 miles, but so far no help or comments. I've had over 200 views but so far no reply. Help if you can. Maybe I posted in the wrong area, not sure. I am new to this and I'm trying to get help with a problem.
Here is what I have been asking for help with. I just purchased the car, put new injectors, fuel pump/filters all changed, new battery & tires on it and took it for a high speed run on the I-10 (I'm down in Phoenix area). When I bought the battery, I bought a key chain battery also. After the run I played with the key chain clicker a number of times to see if it worked. Wouldn't lock the doors but it made all kinds of noise under the hood....finally got it to quite down and I left it set. I went out to start it this morning and it turned over fine and started, for 5 seconds, then a clunk. Cannot get it restarted.
I thought it might be out of gas, so I added 3 gallons just to make sure it had fuel.
I cracked the line on top of the motor to make sure there was fuel...yep it was there, pulled a plug and saw spark. Darn thing will spin but no start.
Does anyone know if the anti-theft will stop it from starting, and how can I solve? Also, can the fuel pressure be checked on these puppies? Thanks Marv T
siliko
04-12-2008 06:51 PM
cdziblnd
06-27-2007 04:41 PM
detox2181
09-22-2004 11:09 PM
