a little baffeled
#11
RE: a little baffeled-Solved
I have solved the problem!!!!!!!!! This is almost embarrasing. The tires had taken a set (slightly cupped from being out of balance and or alignment) and were rotated when they were balanced and aligned. This put the cupped tires on the rear and caused a vibration. After a couple of hundred miles they were smoth again and the vibration has dissapeared. Smooth as silk now.
This was pointed out by a tire dealer and his prediction was correct.
Thanks for all your help,
Randy
Randy
#13
One would have thought that the bonehead balancing your tires would have seen that. Specially knowing that you had a vibration problem !
You just can't get good help anymore !
89_260e
08-18-2005 01:35 AM
autobahn_burner
08-11-2005 04:43 AM
