Kickdown causes rough running (S320 - 2000)
Hi
Recently, I found that if I use the kickdown, the engine loses power, runs rough unless I restart the engine and avoid kickdown. When this happens I olso can hear a clicking on the radio like the noise you used to get when a spark plug was shorting. Any ideas? Thanks Hugh |
RE: Kickdown causes rough running (S320 - 2000)
You don't state if you get a Check Engine light.
Next step is to read if there are any codes stored in the On Board Diagnostics. an appropriate scanner is required for this purpose. If you have a misfire for some reason the engine may go into Limp mode (run rough). This can be cleared by a restart. If this is the case we need to understand what caused a transient misfire. This is where the codes come in. What, if any, event can you assign to the start of the problem. Refilled with gas (possibly bad?), car wash etc. |
Hi
Thanks for the reply No Enine Light or other messages appear, after kickdown it just runs in what I guess is Limp Mode until restart. No scanner available so i guess its a dealer job... BY the way, any idea where I can get a guide to te fuses in the car? BW Hugh |
Since I have a similar vehicle I will try to anser this one for you over the weekend. Got an email address so that I can send some pics. I've sent my email via private messages. Stuart
