Instrument Cluster not working
Question on Instrument Cluster.
The speedo, temp, tach, oil pres, mpg, and fuel gauge are not working.
The red light bat, ABS etc do come on when I turn the key. So there is power at least to some extent here.
Checked the main fuse to the panel it is working.
I see the whole Instrument panels for sale used. I can’t imagine all of those gauges going out at the same time. I am going to remove the cluster, is there a circuit board in the unit to check? Are these controlled by any of the Module’s that this 500SL has?
Not sure where to start!
1992 500SL
1992 500SL
