Installing WIS
Please could anyone help me with a prob i have installing WIS on my P.C
I have installed the WIS on a laptop and all works ok,But when i put it on my P.C
it all installs ok but in program manager all i get is 3 big blue question marks as icons and the WIS will not run. Many thanks mark ( p.s i have been working on mercedes cars for 18 years if i can help anyone else i will try my best )
SINCE THE WIS IS ALREADY ALL WORKING OK, WHY ELSE SHOULD YOU WORRY ABOUT THE DBPM?
IF YOU WANT TO SETUP THE CONFIGURATION, DEFAULT PASSWORD AND USER IS: ADMIN
MAKE SURE THAT YOU HAVE THE LATEST SERVICE PACK, LAN ID AND LICENSE KEY.
LICENSE KEY ALSO DEPENDS ON IF YOU INSTALL IT TOGETHER WITH ASRA, AND EPC. DAMAGE CODE IS STANDARD.
Dear Sleepwalker
thanks for the reply, The wis will not work if the program manager is not working as well.
and so i can not enter my key number for wis if it is not working, i had the same prob when it was put on the laptop, but i have tried the same thing on the P.C and had no luck.
I think that it is a common prob when the WIS is first installed as when i spoke to mb thay new all about it. I have the latest dvd of WIS/Star and it is up dated every 4 weeks.
i havent spoke to them this time as it is i mind field. but may have to yet
thanks MARK
thanks MARK
BUT YOU WILL NOT BE ABLE TO INSTALL THE WIS IF YOU DON'T INSTALL THE PROGRAM MANAGER FIRST. IT IS THE FIRST THING THAT YOU NEED TO INSTALL.
IF YOU WERE NOT ABLE TO INSTALL THE PROGRAM MANAGER, IT IS IMPOSSIBLE TO INSTALL THE WIS AS WELL.
DID YOU USE THE DISC CACHE?
WHERE EXACTLY IS YOUR PROBLEM?
WHAT IS YOUR OS AND SERVICE PACK?
I ALWAYS INSTALL THIS THING AND SEEMS TO HAVE NO PROBLEM AT ALL.
I AM USEING WINDOWS XP PRO, ON BOTH COMPUTERS
THE DVD I AM INSTALLING IS SD/WIS/ASRA 08.04
I INSTALL BOTH PM AND WIS AND IT SAID INSTALL IS SUCCESSFULL AND THEN RE-BOOTS
I HAVE TRIED BOTH WIS AND WIS LITE,WITH NO LUCK
WHEN I OPEN UP PM ALL I GET IT 3 BIG BLUE QUESTION MARKS AS ICONS EACH NAMED AS WIS,MB DOC,AND NOT PAD.
I CAN NOT ENTER MY UNLOCK CODE OR CHANGE THE LANG IN THE WIS, THE WIS WILL OPEN UP BUT WILL NOT WORK
