How to Replace Engine Fuel Filter for Mercedes W212
how to change the engine fuel filter on Mercedes-Benz E-Class W212 Diesel engine(OM651), but the procedure is mostly the same for other models.
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-1.jpg)
Procedures:
Open and close the fuel cap to lower the pressure in the tank
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-2.jpg)
Remove engine cover
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-3.jpg)
Use plier for click clamps part-nr 171 589 0037 00, these tools are not recommended by MB.
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-4.jpg)
Remove hoses by hands or plastic tools
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-5.jpg)
Hose clamps part-nr
13-14.5 mm A006 997 18 90
14.5-15.5 mm A004 997 20 90
Important: hose clamps should not be reused
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-6.jpg)
Take out old filter then replace a new filter from BOSCH
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-7.jpg)
Inspect the hoses for cracks, if you find damage the the hose, it should be replaced
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-8.jpg)
According to the MB documents, key should be in position(2) under 5 seconds to fill the new filter before start.
Turn the ignition on, check for leaks
![](https://www.car-auto-repair.com/wp-content/uploads/2021/06/How-to-Replace-Engine-Fuel-Filter-for-Mercedes-W212-9.jpg)
No leaks put the engine cover back
more information at www.cnautotool.com
hope it help!
Procedures:
Remove engine cover
Hose clamps part-nr
hope it help!
TerryD
02-27-2022 03:01 PM
OSEK
09-29-2014 01:34 PM
PelicanParts.com
10-02-2013 06:09 PM
